Why won't this ramp parameter work?
   4494   4   0
I have a VEX shading network that is supposed to read in a point attribute from geometry. I then use that attribute to drive a color ramp. However, the ramp doesn't seem to work. Anyone know what I'm doing wrong?
vexRampBug.hipnc (79.5 KB)
www.kmcnamara.com
I checked your file and this is OK !?
Maybe this is bug in your Houdini version :?
Also you can type “1-$PT/$NPT” expression instead of “fit($PT, 0, npoints(”../line1“), 1, 0)” !
Rabiee.Sadjad@Gmail.Com
Thanks for the reply - Did the strip render blue and white for you? No matter how I change the ramp it always renders with an even white to black gradient.
www.kmcnamara.com
the rampTest node under /VEX is just the definition of your shader
the actual instance of that shader which you are using to shade your curve is in /SHOP/rampTest1 so you need to tweak ramp on that node instead
and maybe rather than defining your shaders as VEX Shader Types (which is quite old way of working) you can just build them directly in SHOP context and convert to HDA if you need more instances with the same UI
CG Supervisor
Framestore, NY
Good point on both counts 8) Works great. Thanks!
www.kmcnamara.com
