Save geometry as vector file
   3776   2   1
Is there a way to save a scene as a vector file, for placing into Illustrator for example?
I found that I can save geometry as a .dxf (which is recognized by Illustrator), by using a node's context menu, but this saves only a side view of the object.
Can I choose a perspective view or a camera?
Check “Wren render node”.Maybe it's usefull for you :?
Rabiee.Sadjad@Gmail.Com
Houdini saves out the whole 3D object in the dxf file. If Illustrator is only projecting it at a side angle, then it is a problem on the Illustrator side.
