I know in mantra node, here is a parameter “use max processors”. but I don't think it can control CPU usage very well and PC still lag.
so I go to the windows task manager(WIN7 64bit) to turn off some CPU for mantra. but it will turn on all CPU automatically…
any idea? please.
is possible to decrease num of CPU use task manager
4853 3 1-
- igou
- 102 posts
- bollili
- 214 posts
I am not sure, if I understood you correctly…
As an alternative to restricting the number of used cores (in the mantra node, as you mentioned), you could switch the priority of houdinifx.exe-process to “lower than normal” via right-click the process in the task manager. All mantra.exe processes, started by this houdini session will inherit that setting.
- KMcNamara
- 228 posts
- igou
- 102 posts
