How would you do this...
   18894   36   7
That look's so good eetu! I'm having license issues at the moment, but will try it as soon as posisble.
This is pretty interesting
Here is my attempt, I came up with it after seeing owlYzarc use of voronoi, But in my case I got rid of the forEach loops.
It can be use with eetu's way of ray-smooth at the end, or with vdb-fracture… in my case I prefer how the vdb one looks
and it also solves the problem with eetu's for non planar cases.
check it out
rbp_cellSeparation_0424.hip (146.7 KB)
robonilla
check it out
Oh but of course, voronoi is indeed the 3d equivalent of a dual, simple and beautiful!
Sweet
had made something similar for soup bubbles few moths ago, but discarded it as failed test apparently should have continued in that direction
thanks!!
Here's yet another idea, needs further development, though.
I'm just raying points inward and checking if it hits other geometry (means an intersection). The problem is getting the proper direction to shoot the rays, it should be normal to the plane separating the two spheres. Now i'm just running a helper raycast, importing the normal direction of anything it hit, and using that to do the real raycast from the original surface. It's wrong, but closer than just raying along negative normal..
rbp_cellseparation_ee.hip (157.7 KB)
eetu
I think it would work like the attached. Can't test it right at the moment, but it should..
edit: Oh, and if the spheres are of different sizes, then just multiply the normal vectors by that value when finding the origins..
Ok implemented the above, works pretty much as expected, although it has problems when there is an overlap of more than two spheres.
rbp_cellseparation_ee2.hip (919.5 KB)
Doesn't the fuse1 node take care of that?
Anti-Distinctlyminty
Well, yea, but that's side-stepping the issue. If you have animated points, you can't just delete particles when they are close to each other. Then again you wanted to have the cells try and keep each other at a distance, so maybe that'd be enough.
I haven't tried, but I suspect there might be some popping with the dual/voronoi method, however elegant that seems on first look. I would still bet that the foreach-methods earlier on this thread are the ones that will be the most reliable in the end..
True, I need to take a closer look at the previous solutions and properly understand them.
I did animate some of the points earlier, and for the most part it worked well, but when two points are close and they move past each other, the flip is quite extreme.
How about using a particle sim to keep the points a certain distance from each other?
That combined with the stuff from the other thread
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=31451 [sidefx.com]
about confining particles to an arbitrary surface and that should work. Maybe?
Just been fiddling around with this - just trying to learn the current best method for getting cells before I can progress to the actual cell division.
Results are ok-ish, but there's something weird going on with the voronoi fracture that are causing gaps to appear in my layer of cells.
Any thoughts?
Edit: Just having a look at eetu's solution posted above. Seems a lot better than what I have Figuring this stuff out using a tiny netbook is kinda difficult .
Edited by - May 16, 2014 09:28:54
cell_divide.hipnc (181.8 KB)
try feeding only points without geometry into second input of voronoi fracture sop
Yeah, that seemed to work. Weird, as I thought that the voronoi only took account of the points anyway.
eetu
Was the one with the for loop ever posted?
eetu,
The results with the 2-stup ray casting were a bit off sometime, but I had another idea, but my lack of experience with Houdini is holding me back.
To find the correct direction to ray cast the geometry, can we somehow use the vector gradient of an SDF volume? That should always point in the correct direction I think.
eetu,
Yep, that is a very common technique, see attached. Ray SOP with Minimum mode should yield a similar result.
ee_sdf_gradient.hip (75.4 KB)
