Hi All ,
Parameter DCM composite samples < What is this doing when checked on ?.
On a side note in Nuke. I can read the deep samples so the data is there, although I cannot see any data in deep.front when trying to view in the alpha channel. Is there any way just to view deep.front in EXR2.0 ? .
Rob
3693 4 0-
- circusmonkey
- 2624 posts
- eetu
- 607 posts
I don't have nuke here so I can't verify, but simply put: if you have three semi-transparent surfaces of 50%, you will get samples of 50%, 50% and 50% with the option disabled, and 50%, 25% and 12.5% (from front to back) if enabled.
For the side note, do you have a recent build of Nuke? The early 8.0 versions had real trouble with Houdini deep exrs..
- circusmonkey
- 2624 posts
- eetu
- 607 posts
Would be nice to get an authoritative answer (as I can't confirm atm), but I think the premultiplied/unpremultiplied state of individual samples is unaffected by this parameter, it only affects the compositing resulting from “stacking” the samples in one pixel.
I'm sorry I don't remember what got fixed in which version, just that in the beginning of 8.0 cycle it was really broken. Like with Houdini, when in doubt, test the latest build..
- circusmonkey
- 2624 posts
Ive upgraded to v04 build, fixed the display issue, but now theres a ew other issues with workarounds. Noted the RFE for Houdini to output deep.back which would be nice. Of note I have getting constant crashes in Nuke when rendering with DCM - pre composite samples turned on. Ive got a few more tests to see what I can come up with in optimizing the files.
Rob
Rob
Gone fishing
