String matching
   10542   6   2
I am trying to use the “match” vex function like this:
i@mymatch = match("obj_",@myattr);
Instead of matching attributes with 10,12,13 values it matches with 1,0,2,3.
What would be the correct way to match decimals?
See here
http://www.sidefx.com/docs/houdini13.0/vex/functions/match [sidefx.com]
*z - Match any string beginning with a, b or c and ending with z.
So, try to match 1, 0, 1(but already tested), 2, 1(tested), and 3.
I think you may try with this expression
you'll need to do
obj_1
for your case, but as houdini's patterns are slightly more limited than regular expressions it may easily happen that you can't create simple pattern covering all the matches you want
so you can just use these rules
http://www.sidefx.com/docs/houdini13.0/expressions/_patterns [sidefx.com]
CG Supervisor
Framestore, NY
Thanks for the feedback guys!
I'll try that.
Hi guys!
Here I am again with another question regarding matching strings in vex.
What would be in VEX the equivalent to the strreplace() expression?
I want to to change a attribute like:
$HIP/texture/mytexture.jpg to $HIP/texture/mytexture.rat
I would like to to that in a wrangle node is it possible?
I think that's quite limited with current VEX functions, you could split() the string based on “.” to array, then replace last element with “rat” and than assemble back to string, but that feels like too much work for something that could be done easier
if however replacement of string attribute is what you are after, then have a look at AttributeStringEdit SOP, where you can even use regular expressions for substitutions
CG Supervisor
Framestore, NY
Cool! i'll try that for sure.
Thanks Thomas! Can I call you Thomas?
Thanks for the help, again!
