Cannot import any geometries
6545 12 0-
- Jens Cornelis
- 7 posts
Hi there,
i am testing Houdini Apprentice. I try to import some geometries, but no matter what format (obj, ply, etc.) i try to import, the File node says “Unable to read file….”.
I tested it with many different formats. Converted formats using Blender and Meshlab. I tested 2 different installations on 2 different machines and OS's (Windows and OSX). Same problem.
Am I just missing something. I am going slightly mad.
- tinyparticle
- 175 posts
Hi Jens,
Can you share one of the files you are trying to import if possible please ? I would like to see if can import it or not. If I can import it then chances are you are doing something wrong about importing, if not then the chances are that the file may be corrupt.
Jens Cornelis
Hi there,
- anon_user_37409885
- 4189 posts
- Jens Cornelis
- 7 posts
- Jens Cornelis
- 7 posts
It's even worse. When i uncheck “Show sequences as one entry” option, the file can be read, but it is modified such that it has 0 faces, vertices, etc. After having opened it in Houdini, it is broken. Before, it is fine.
Edit: Okay, i cannot reproduce this behaviour. It happened for 2 files i tested. But did not happen anymore since then.
- 4189 posts
- tinyparticle
- 175 posts
- Jens Cornelis
- 7 posts
- 4189 posts
- tinyparticle
- 175 posts
- Jens Cornelis
- 7 posts
- Jens Cornelis
- 7 posts
- tinyparticle
- 175 posts
