Hi there,
I am pretty new to Houdini so forgive me if I am asking soemthing basic. I have just imported an .obj file in Houdni made it a static body I also have a particle emitter also in the scene. The particles are present through all 240 frames however my .obj vanishes after the first frame but is still causing a rigid body effect on the particles throughout the rest of the animation.
Could anyone please advise what I may be missing?
Thanks in advance!
Rigid Body disappearing in Houdini animation
5151 3 1-
- Rob Short
- 3 posts
- edward
- 8171 posts
Does your .obj file have a number in it? If you picked it from the file chooser, you may have left import file sequences enabled which would have did something like “file$F4.obj”. Then when it expands at a different frame, it becomes an error because you don't have a file at the other frame. Just make sure your string has no $F4 in it (replace it with the actual number needed).
- Rob Short
- 3 posts
- Rob Short
- 3 posts
