Issue with z-depth pass
   2606   3   0
What's wrong? How i can get a png sequence for import to After Effects.
P.S. I tried to export to other formats, but it was unsuccessfully.
untitled.hip (969.6 KB)
-1 копия.jpg (489.6 KB)
Z depth pass needs to be a 32bit float image and you need the filter set to closest surface .
rob
Gone fishing
circusmonkey
rob
The result is the same
The brightness and offset in step 2 are just for preview purposes in mplay. You need to recreate those steps in your software to get the same result. Also, does .png even go to 32 bit? You can maybe do the brightness adjustment in houdini and then output the result as .png. Be sure to make actual adjustments to the image and not to the image preview.
