Hi!
I'm trying to create a morph effect using a Point VOP.
I started by creating a simple morph using a mix to interpolate position attribute.
Now I would manage my effect using a controller. I created a controller and in a Point VOP I would like to calculate the distance between the point of my goal and the position of the controller (to make a ramp) . The problem is that the distance VOP return the same value for all points …
Here the file for more precision
Distance VOP
3764 2 1-
- Robin PELISSIER2
- old_school
- 2540 posts
The fit range VOP clamps to output min and output max parameters. You left these at default so you are getting values from 0 to 1.
Replace this with the ramp unclamped VOP.
but then you run in to the Ramp VOP which again will clamp values again.
Re-think your logic? How you want to present the controller to the user?
- robP
- 8 posts
