How emit particles , once ?
   11950   4   1
Hi;
I would like my particle source emits just 100 particles at first frame , but the problem is, the emitter creates particles in each frame continuously…
How could I create just 100 particles once at first frame?
Thanks for helping.
:roll:
Edited by - April 15, 2016 15:33:47
Masoud Saadatmand (MSDVFX)
The particle system default to continuous emission. Set Continuous Activation to 0 to turn it off, then set Impulse Activation to an expression.
This will only emit particles on frame #1.
$FF == 1
Other expressions are also possible like.
$FF < 12
Will emit particles for the first 12 frames.
ap_particle_mit_on_frame_one.hipnc (245.6 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
$FF == 1
$FF < 12
Thank you Enivob , but I can't find “ Continuous Activation” parameter…! :?
It is under the Birth TAB. Look for the green field in my example file. It is right under that.
Enivob
Thanks.
It works …
