I am trying to group fracture pieces randomly in different groups so that I can split it further into small or medium pieces, but I want to keep track of the pieces.
How would I group it based on name attribute.
group based on name attribute
13576 7 2-
- rizviali110
- 79 posts
- circusmonkey
- 2624 posts
- rizviali110
- 79 posts
circusmonkey
You can output groups in the fracture sop ie chunk_1 etc etc . So in many ways all you need to do is create a attribute based on the chunk number you want to shatter more
Rob
thanks for the reply, you mean voronoi fracture? how would I call it inside a group after it, for example if I wanted to pick a range randomly? and other range different from the previous range.
FX - Artist / TD
- rizviali110
- 79 posts
- williamjohn
- mestela
- 1853 posts
Sounds like you found the solution you wanted, but in the name of completeness, a partition sop will do exactly what you want, ie, its purpose is to make groups based on attributes.
Eg, if you have a fractured object that has a name attrib for each chunk, you can append a partition sop, set the rule to $NAME, you get a group for each name.
Was surprised it worked with $NAME, but not @name, whereas the colour example works with @Cd. Oh well.
- rizviali110
- 79 posts
