RBD - objects suddenly stop moving, although they have some "momentum"
   4534   2   1
Hello, please see the attached file.
I have tried RBD and Bullet solver … and at a certain moment the solver “ignores” the object's momentum and stops the object. Is there some parameter, which determines the “sensitivity” to small movements?
rbd limited time.hipnc (143.7 KB)
It is called ‘sleeping’. Try turning off Enable Sleeping on the broken_ball node inside the PartitionBall1 network.
The solver attempts to put participants to sleep after a certain amount of time.
Edited by Enivob - July 11, 2016 08:55:03
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Perfect, Enivob, thank you very much!
