Atmospheric fog/dust setup
   18249   9   5
Hello guys! Could you help with advise,to show the right way,how to setup dust like this? Thank you!
https://vimeo.com/64857224 [vimeo.com]
My feeing is that it is using pyro but feeding a custom built wind force with turbulence to achieve those beautiful swirls.
Thank you for the answer! I'm troubling with starting point of simulation,can you tell me with few words pls,from what do i start the simulation,if it's a abit big scale simulation.Should i make a volume from some big scale geometry for example? Thank you!
You can create elements like that with a combination of pyro FX and a simple volume box with some noise run through it
Rob
Edited by circusmonkey - Sept. 20, 2016 17:59:06
Gone fishing
Because this is most likely going to be a pretty large volume, I would first attempt to do this with pop particles that are fed to the ‘volume rasterize particles’ node.
I've included a quick example. Hope it helps.
Edited by iamnelsonlim - Sept. 21, 2016 15:58:06
atmosphericDustAndMistSetup.hip (325.9 KB)
Blog: https://www.nelsonlim.com/blog [www.nelsonlim.com]
Instagram: https://www.instagram.com/iamnelsonlim [www.instagram.com]
Youtube: https://www.youtube.com/nelsonlim [www.youtube.com]
Thank you guys for advises!
Quinton84 thanks so much for the setup! That's exacly what i needed,i will go thru the setup now.Thx you for help!
Thanks for this base setup! Super useful as a beginner myself!
Thanks for this as well. i love how simple it is.
I love how simple it is. Thanks!
THX for you sharing!
