Hello everyone, I haven't being touching Houdini for 2 months now and have some troubles in understanding where to place the related texture files above on the shaders.
I've tried placing the map under the Reflect Intensity. But unsure as of what to do with the Glossiness texture map.
Need some advice on this, thanks.
Where to put [Glossiness, Specular & Ambient Occlusion] texture map in Matrasurface & Principled Shader?
31390 11 1-
- YH
- 57 posts
- blackpixel
- 182 posts
- YH
- 57 posts
- blackpixel
- 182 posts
- robsdesign
- 240 posts
Hi, I recently posted about something similar to this here https://www.sidefx.com/forum/topic/46543/?page=1#post-208083 [sidefx.com]
Note: When using a texture for Roughness, the slider (which you have set at 0.3) determines how much of the texture is used for the Roughness value. Set this to 1 to get the full value from the texture and you should see much more of a difference. I use Substance Painter for creating textures so I prefer to use correct Roughness maps rather than trying to tweak the sliders.
For a mix of metallic and non-metallic materials, you could use a Metallic map. This works well with the Principled shader when used in a Metal/Roughness workflow. (ie. Base Colour map, Roughness Map, Normal Map, Metallic map) The metallic map will determine which areas reflect the Base Colour (metallic) and which do not (non-metallic).
This doesn't work as well with the Mantra Surface Shader because instead, the Metallic map determines which areas use the Reflect Colour (specular colour) and which do not. One of the advantages of a metal/roughness workflow is to avoid creating Specular colour maps so I tend to use the Mantra Shader only for refractions or non-metallic materials.
hope that helps
Rob
hope that helps
Rob
- bhb
- 67 posts
¿ Where to place AO Ambient Occlusion texture map inside Principle Shader??
There is any slot for it. ¿?
In principledshader:
-Base Color
-Metallic
-Reflect
-Reflect Tint
-Roughness
-Anisotropi
-Anisotropi direction
-Subsurface
-Sheen
-Sheen Tint
-Coat
-Coat Roughness
-Surface Texture Settings
And…¿AO?
Somebody could upload a simple example file or link to a tuto??
Thanks in advance.
-Base Color
-Metallic
-Reflect
-Reflect Tint
-Roughness
-Anisotropi
-Subsurface
-Sheen
-Sheen Tint
-Coat
-Coat Roughness
And…¿AO?
Thanks in advance.
- 8240 posts
- bhb
- 67 posts
Yes jsmack, its for a game engine, in this case Unreal Engine 4.
I can export all textures map automatically conected to their respective slots, except for the AO map.
I have both Houdini materials from another post with AO (occlusion VOP & takes), but non of them are exported to UE4.
Edited by bhb - April 12, 2017 20:38:35
- Olaf Finkbeiner
- 323 posts
- bhb
- 67 posts
Olaf, I refer to the conections.
Houdini > Houdini Plugin for UE4 > UE4
https://www.sidefx.com/products/houdini-engine/ue4-plug-in/ [sidefx.com]
All textures are automatically conected to UE4 material slots (base color, metallic, specular, roughness, opacity, normal map.); except Ambient occlussion map.
- 8240 posts
OH, you are talking about a plugin that translates a mantra material into a unreal one. Now I understand. The plugin can probably only translate maps that are actually used by the mantra material, since AO is not used, it doesn't have any automatic mapping. The ‘bake’ outputs of the material are not applicable in this instance, as only the material inputs are considered. Maybe the plugin author could chime in on that.
Edit:
These appear to be the only documented mappings:
The docs in question
http://www.sidefx.com/docs/unreal/_materials.html [sidefx.com]
possibly out of date for houdini 16
Edit:
- Diffuse | ogl_diff, basecolor
- Opacity | ogl_alpha
- OpacityMask | ogl_opacitymap
- Normal | ogl_normalmap, normalTexture
- Specular | ogl_specmap/ogl_spec, reflect_texture/reflect
- Roughness | ogl_roughmap/ogl_rough, rough_texture/rough
- Metallic | metallic_texture / metallic
- Emissive | ogl_emit, emitcolor
Edited by jsmack - April 22, 2017 04:23:51
- bhb
- 67 posts
Thats is jsmack!
There is no mapping for the AO texture.
I think that a temporaly fix should be to attach the texture to the specular slot (normally not used in UE4), and then “manually” change the texture from specular to Ambient Occlusion inside UE4. .. But this is more workflow, not automatic.
Thanks for your time jsmack & Olaf.
Thats is jsmack!
