Get channel from VOP?
   3743   9   1
Can I get a channel from VEX Builder?
Edited by Unaided - Jan. 4, 2017 03:29:36
Moin,
> I can get a channel from VEX Builder?
Yes, you can.
Marc
P.S. If you mean the question in a different way, try describing what you want to do - or maybe post an example file
Good bye.
Thank you malbrecht
It was a quick doubt that I had
I would like how call to channel from VEX builder, the same way as expression is ch(“/path”)
If I understand your question correctly, then you do just that - use
ch('path')
, maybe the specific version of ch, to get the correct casting.
I haven't used the VEX builder context for more than about a few seconds, but I noticed there's an “inline code” node, that should do the trick … I hope.
Marc
Good bye.
Well, with channel I'm refer to parameter.
… and what is your question?
You're not in the VEX builder in that screenshot.
Sorry, I give up - I don't understand what response you are actually looking for.
Marc
Good bye.
From wrangle I can get or call to parameter from connected SOP for example, with ch('path').
I find how do this into VEX Builder.
Edited by Unaided - Jan. 4, 2017 05:07:59
https://www.sidefx.com/forum/topic/47621/?page=1#post-214140 [sidefx.com]
Good bye.
I've tried this when you are show me ‘inline code’ in your previous post, but my vex builder becames wrong. So I should try again and review my vex build.
Thanks Marc
Maybe post your hip file and let us know which parameter you want to reference
You may need to prepend it with op:, or use chi, chp, chs etc.
