The auto-license aquisition has not worked for me on Windows for months now, but it hasn't been a problem until today. I cannot get an HDK license, and there does not appear to be a way to do it manually on license.sidefx.com. So, what do I do??
Incidentally, Linux works fine on the same machine with the exact same Internet settings…
Peter B
HDK license manually: How?
7759 8 2-
- pbowmar
- 7046 posts
- Stephen Gurban
- 11 posts
- edward
- 8083 posts
Hmm, this looks like a Standalone Mode in the license server problem (on Windows). To fix this, start up the License Administator. In the top File menu, choose Change License Server. In the dialog that pops up, turn off Use Standalone Mode. In the License Server Host input, make sure it's the right name, you can try clicking on the Local Server button if it's wrong. Now click OK and exit the License Administrator. Everything should now work.
- Stephen Gurban
- 11 posts
Edward,
you're a legend. Thanks very much for that. It did the trick.
I take it that I don't need to have the License Administrator running before firing up H8? I tend to do that through habit - because it worked back with Houdini 7.
Cheers and Beers
Cheers and Beers
Gurbo
______________________________
Still on my training wheels
- edward
- 8083 posts
- pbowmar
- 7046 posts
Soooo, you turn off Standalone just to collect licenses, then turn it back on, right? I'm using DHCP, so I need it on.
Incidentally, how's Standalone mode for Linux coming along? It's a real pain the ass right now having to switch from DHCP to fixed to run Houdini on my Linux laptop.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- lucas
- 269 posts
- pbowmar
- 7046 posts
- Stephen Gurban
- 11 posts
