So I'm newer to houdini coming from 3ds max, and in modelling how can I simply duplicate an edge which is selected? In 3ds max I just had to select what I wanted and then hold shift and drag and that would make a copy, is their something like that in Houdini which I'm missing? seems like a must have, but i can't for the life of me find it, is it a keyboard shortcut like 3ds max or something else? I feel so dumb asking this but it's just not right in front of me like in 3ds max.
Thanks,
Daniel
Can you duplicate 'Edges'?
10994 4 2-
- Kaboose1066
- DASD
- 490 posts
This duplicate operation is actually not a standard in modelling packages. It is like an invitation to create bad geometry, but I agree that it should be available in every package.
In Houdini you can use a blast or delete node to isolate a selection, then move it with a transform node, edit node (or manipulate it with many many others) and then merge it with the geometry that you got it from. You could also build a shelf tool or Houdini Digital Asset (HDA) to automate this.
- zbynekkrulich
Hi, this is the exact thing I was missing in poly edit mode. It is super fast because just by holding shift and draging a mouse you could specify two things in one click (1/ extrude operation, 2/ extrude lenght). When you are using snap tool you also get specific lenght. This way I feel more like sculpting than clicking..
But hey, you could use polyextrude of selected edges, and you will also get several useful parameters.
Hope this helps
Hope this helps
- 8177 posts
- DASD
- 490 posts
