select tool's '3D Connectivity' in nodes
   3648   8   1
Does anyone know which nodes can be used to create the same thing as the select tool's ‘3D Connected Geometry’? Specifically after the Boolean node, the +3D creates some very nice islands.
thx!
Screen Shot 2017-05-24 at 5.11.15 PM.png (55.3 KB)
I think you look for the connectivity SOP and partition SOP
Very cool, thanks! Works!
Out of interest is there a better way to do this now we use attributes everywhere? i.e. loops etc. as it only works by ‘checking Local Variable’ in ConnectivitySOP. Seems old skool.
The Connectivity sop should just outputs an attribute starting at 0. So there should be no need to turn on local variables? Or am I missing something?
Maybe you can post an example?
Here we go, want to get the slices as groups but they only appear when the Local Var is switched on.
_ConnectPart.hiplc (62.3 KB)
use partition SOP to partition the geo based on the class attribute with Rule:
group_`@class`
thx! works perfectly
also, no need to create groups, now that as you say we use attributes everywhere
CG Supervisor
Framestore, NY
hey - do you mean we don't use the Group field anymore?
