HQueue Problem
3662 2 1-
- IlichFX
- 4 posts
- rvinluan
- 1495 posts
Sounds like the HQueue jobs are trying to access a network folder path that does not exist. By default, HQueue jobs try to launch Houdini from a network folder location. For Windows, I recommend configuring HQueue so that it launches Houdini from a local install instead.
In your HQueue Render or Simulation ROP, set the Target HFS parameter to this:
where
Then re-submit the job.
Rob
C:/Program Files/Side Effects Software/Houdini 16.0.ZZZwhere
16.0.ZZZis the number of the Houdini build that you have installed.Then re-submit the job.
Rob
- Alex Kravtsov
- 21 posts
rvinluan
where16.0.ZZZis the number of the Houdini build that you have installed.
Rob
Hi, Rob! I have issue with client machine. Each time i submit the job it fails with this: “Could not find output file for job ‘19’.” Can you help me?
Thanks!!!
