Split geometry into sections - detach
7070 2 1-
- enni
Hi there – was wondering if houdini can split geometry (1 object) based on a shape (plane) – the idea is to split an architeual facade into multiple parts. We use maya usualy but its not managing the polycount (over 10million tri) – if this is possible in houdini we are considering to pick up a license. Thanks!
- neil_math_comp
- 1743 posts
Does the Boolean SOP work? If it's an infinite plane, you could try the Clip SOP. Depending on what you mean by “split … into multiple parts”, a Group SOP, Delete SOP, Blast SOP, or Voronoi Fracture SOP might do what you need. 10 million might take a while to handle for a complicated operation like Boolean or Voronoi Fracture, but should work.
I think you can try things out in Houdini Apprentice for free to see if Houdini will suit your needs before buying a license. I'm not an expert in licensing, but I do know that if you buy a license, you can do a one-time submission of scene files and assets you made in Apprentice to SideFX support to be converted for commercial use.
- vusta
- 555 posts
or Boolean Shatter ?…ie. the plane(s) shatter some geo into pieces
or even this ?
forums.odforce.net/topic/30812-quick-slice/
or this
http://forums.odforce.net/topic/30871-3d-slicer/ [forums.odforce.net]
or even this ?
or this
Edited by vusta - Oct. 31, 2017 02:12:40
