Fatal Error : Segmentation Fault with Houdini apprentice version
   19788   5   1
Hi everybody !
I’m new on houdini, and as I was trying to work and discover Houdini, after about 4-5min of work I had this error :
Segmentation Fault !
I joined screenshots of the soft when the error appears and a sc of the report !
I don’t know how to fix it, I tried to reinstall it but the bug was still there (I also reinstalled my gpu driver).
I have a msi with:
Intel core i5 6300 HQ
GeForce GTX 950M
8 go Ram
Windows 10
I hope someone will help me to fix it !
I've been having the similar issues since the start of the year, finally fixed it. From what I can tell it was the TdrDelay being too low.
See this forum post
https://www.sidefx.com/forum/topic/52656/ [www.sidefx.com]
Here's an explanation for how to change it.
https://support.allegorithmic.com/documentation/display/SPDOC/GPU%2Bdrivers%2Bcrash%2Bwith%2Blong%2Bcomputations [support.allegorithmic.com]
Follow up: Doing a clean uninstall of my Nvidia graphics driver and then installing the latest version fully resolved the issue. No crashes since.
kidkasper
See this forum post
How much you set the TdrDelay to? In substance painter I used 60. How much houdini needs to do a pop source sim ?
Having this problem too, fix from FJSsam does not work for me
After investigation, it turned out that it was because of Nahimic, an audio enhancer software on my laptop which was trying to make sound out of the 3D space. I removed it and then I was able to work properly. Try to see if you have an audio enhancer installed on your computer and remove it, and let me know !
