Hi everybody !
I’m new on houdini, and as I was trying to work and discover Houdini, after about 4-5min of work I had this error :
Segmentation Fault !
I joined screenshots of the soft when the error appears and a sc of the report !
I don’t know how to fix it, I tried to reinstall it but the bug was still there (I also reinstalled my gpu driver).
I have a msi with:
Intel core i5 6300 HQ
GeForce GTX 950M
8 go Ram
Windows 10
I hope someone will help me to fix it !
Fatal Error : Segmentation Fault with Houdini apprentice version
19699 5 1-
- DonRomano
- 16 posts
- kidkasper
I've been having the similar issues since the start of the year, finally fixed it. From what I can tell it was the TdrDelay being too low.
See this forum post
https://www.sidefx.com/forum/topic/52656/ [www.sidefx.com]
Here's an explanation for how to change it.
https://support.allegorithmic.com/documentation/display/SPDOC/GPU%2Bdrivers%2Bcrash%2Bwith%2Blong%2Bcomputations [support.allegorithmic.com]
See this forum post
- kidkasper
- FJSam
- 22 posts
kidkasperHow much you set the TdrDelay to? In substance painter I used 60. How much houdini needs to do a pop source sim ?
See this forum post
- SRal
- 5 posts
- DonRomano
- 16 posts
After investigation, it turned out that it was because of Nahimic, an audio enhancer software on my laptop which was trying to make sound out of the 3D space. I removed it and then I was able to work properly. Try to see if you have an audio enhancer installed on your computer and remove it, and let me know !
