Hello everyone.
There is a way to select nodes interactively base on pick up selection via Python, I use normally hou.selectedNodes(, bus this must expect that the nodes are alredy pre-selected. I need to run the script and wait until I select a bounch of nodes and I press enter to make that selection or store it in a avariable as a list.
More or less like the tools provide by SESI that run in scene.viewer context but with nodes( no geometry)
Thanks in advance
Select nodes interactively
3503 6 1-
- jorgemartinsegura
- 14 posts
- goldfarb
- 3465 posts
check out http://www.sidefx.com/docs/houdini/hom/hou/SceneViewer.html [www.sidefx.com]
make a new shelf tool and pop this in the Script:
oh wait…you want Network Editor selections?
you can use the above and select nodes in the Network Editor - but you'll need to hit Enter in the Viewport…..
import toolutils def getSelection(): """ Get geo selection from user """ active_pane = toolutils.activePane(kwargs) viewer = toolutils.sceneViewer() thingy = viewer.selectObjects(prompt = "Select object, then press Enter to complete.", ) print thingy getSelection()
Edited by goldfarb - Sept. 18, 2018 10:09:06
- jorgemartinsegura
- 14 posts
First of all thanks a lot for the quick answer!
But there is one problem or maybe I didn't explain my self well.
I need to select nodes in Sop context not in Object context, when I use your script allways jump to obj level and its only possible get selection from nodes in obj context not in the Sop context… Did you know if there is a way to do it??
Thanks a lot in advance.
editor compositor
- goldfarb
- 3465 posts
has a bunch of different functions…in the example code I'm using viewer.selectObjects()
but you could use any of the others - for geometry you'd use selectGeometry() and change some of the arguments
- jorgemartinsegura
- 14 posts
Thanks a lot but any of them didn't help me.
I want that returns me a tuple of selected nodes like hou.selectednodes() but interactively.
1 - click seft tool
2 - Raise prompt “ select sop Targets” - thats not a problem
3 - Select nodes in Geometry context ( lets say I select add, merge, and a file node
4 - return me a tuple of the selected nodes when I press enter in sceneviewer).
(<hou.SopNode of type add at /obj/geo1/add1>, <hou.SopNode of type merge at /obj/geo1/merge1>, <hou.SopNode of type file at /obj/geo1/file1>)
What I checked with out succes in the hou.sceneviewer are not working for this purpose (maybe I'm wrong or I dont find the way to do it)
1 - selectObjects do the job but only in obj context.
2 - selectGeometry dont work for the case because require a geometry_type ( prims,points,vertex etc) selection.
Thanks a lot
1 - click seft tool
Thanks a lot
editor compositor
- goldfarb
- 3465 posts
- jorgemartinsegura
- 14 posts
