How to tweak b/w images in the shader setup?
   1977   3   0
Hi all,
What's the best way to tweak B/W images inside a shader setup?
I'm looking for something like a ‘change range’ remap node or something alike the PS ‘levels’ node.
So you can move the black/mid/white points around. I found the ramp node, but it's not entire doing what I need, especially in the mid tones.
cheers!
rob
Apprentice Attribute / Houdini 17.0.381 / GTX 970 - driver 411.63
OK, a ‘change range’ or ‘aiRange’ is a ‘Fit Range’ in H. Check..
But I cannot find anything that would allow me to tweak the black/white or mid level of an image though…
Oh, and isn't there a simple ‘gamma’ node that I can plugin in between color slots?
rob
for gamma, you can use a color correct node or a power function node. A pow() exponenent is the inverse of gamma value.
To reply a bit late..
I kinda forgot all this stuff in in /img, instead of to be found in /mat <insert rolling eyes>
Only thing to figure out last is how to get the result of a comp tree into /mat as a texture.
cheers!
rob
