Adding Python paths to Houdini on launch [Ubuntu]
   3713   2   1
Hi
Trying to install and use a 3rd party Python library
The library is installed and my PATH variable has been edited to point to this install.
Where I am stumbling is how to get Houdini to recognize this path
ie if I open a new Python Shell in Houdini I should be able to do
>>>import mycustomPythonlibrary
and not get an error.
Can anyone help?
Edited by art3mis - Oct. 2, 2018 20:39:23
The Docs [www.sidefx.com] say you place your path in
$LD_LIBRARY_PATH.
Does that solve your case ?
PYTHONPATH is used by the python interpreter to determine which modules to load.
PATH [net-informations.com] is used by the shell to determine which executables to run.
