Hi!
in a primitive wrangle, I created a point at the center of each primitive. I wanted to use setpointattrib() function to set the @N of the new point to match the primitive. I understand that setpointattrib only works on input points but doesn't work with points created in the wrangle with the addpoint function.
How can I easily set the @N of the new point to match its primitive's @N?
-Olivier
create pt at prim center (transfer @N?)
3666 5 0-
- olivierth
- 1184 posts
- 9404 posts
olivierthwhy wouldn't it? Primwrangle:
int pt = addpoint(0, @P); vector N = prim_normal(0, @primnum, .5, .5); setpointattrib(0, "N", pt, N);
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- olivierth
- 1184 posts
I was trying something similar but it did not work. I thought the “setpointattrib(0, ”N“, pt, N);” would not work since the “0” is telling it to set the attribute on the input geometry. Not on the wrangle created points… ?!
Here's a screengrab I did before changing my code (forgot to copy paste in the forum). What was wrong in my code?
Thanks for the help.
-Olivier
-Olivier
- 9404 posts
notice that you are adding your point to geometry referenced by handle 0
so you can also set it as 0 will contain that point, well, maybe not exactly what is happening, but you can think of it that way, obviously it will not work with anything else than 0 at this point
you've put “primN” in there instead of primN
so it will make your N string attribute and set value of “primN” everywhere
but ig you put primN, which is vector variable, it would create vector attribute N with value contained in primN variable per point
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- 9404 posts
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- olivierth
- 1184 posts
