Trouble with bone capture.
   1399   2   1
Greetings,
I'm trying to learn the basic of Houdini rig system and I'm having trouble with capturing in general, in particular, the biharmonic method. Could anyone take a look at what I'm doing wrong?
Thank you.
CaptureTest.hipnc (169.4 KB)
no pictures?
not sure why you're setting the root path…
use a Stash SOP to temporarily prevent the capture from re-cooking
I've added a note to the file.
Edited by goldfarb - Aug. 19, 2019 15:22:44
CaptureTest1.hipnc (186.0 KB)
Training Lead
www.sidefx.com
Thank you, goldfarb, I looked at the file and got it working. I got the Stash and the File SOP working as well.
I did attach some pictures, I don't know what happened.
I thought I had to set the root path for the node to work. The help says the root path: “Specifies the parent OBJ for the bones attached to the input geometry”, so I thought I had to give the path for the skeleton root, it didn't even occur to me to leave it empty.
Thanks again.
