Multi-threading: Single work Item
   4642   8   0
Hi all.
I am struggling a bit with managing multithreading during the processing of the TOPs graph.
I have lots of light work that should run in parallel and the two steps that are memory intensive and need to run in sequence but on all cores.
Things I tried:
Creating new scheduler (set it to single only and the CPU or thread count to max) - this runs but never runs multithreaded.
Setting the FetchROPS to single only and the CPU or thread count to the max - this runs but never runs multithreaded.
Is there some magic to manage the CPU/count on a single work item? It always seems to be single-threaded.
Thank YOU!
Edited by Marti_M - Nov. 8, 2019 09:33:27
Hi, are you setting the Houdini Max Threads parameter in the Job Parms folder?
Yes, I am. Any suggestions?
Edited by Marti_M - Nov. 8, 2019 09:46:26
Are you able to attach your .hip file?
BrandonA
Indeed the scene is attached.
ISLAND.hiplc (1.8 MB)
Hmmm, I'm not able to reproduce the problem. I'm seeing max utilization across all of my cores when I run the ROP Fetch. A couple questions:
- Which Houdini build are you on?
- Which operating system are you using?
Latest production build. 17.5.425
-Which operating system are you using?
Win 10 currently
will try to nuke my preferences and see if it helps.
Edited by Marti_M - Nov. 8, 2019 11:02:32
Update resetting prefs helped. Thank you for the help Brandon (kinda pointed me to it is me not you") direction! Now to figure out what was the culprit.
M
Edited by Marti_M - Nov. 8, 2019 11:11:33
No problem! When a job is scheduled by the local scheduler, it will set the job's HOUDINI_MAXTHREADS environment variable to the value of its Houdini Max Thread parameter. If something in your environment was overwriting that value, that may be a potential culprit.
Glad that it's working now!
