Alembic visibility inside LOPs [SOLVED]
   5531   7   1
I have an alembic with objects hidden. Is the correct workflow to use the “configure primitive” LOP to change the visibility back to visible? (attached images)
I tried that without sucess…
Edited by guilhermecasagrandi - May 25, 2020 13:23:00
Anotação 2020-05-21 232650.png (37.3 KB)
Anotação 2020-05-21 232707.png (31.8 KB)
viz.hiplc (144.4 KB)
I managed to fix with a wrangle and the function: “usd_setvisible(0, s@primpath, 1);”
One question on that: why “s@visibility = ‘visible’;” don´t work?
I'm not able to replicate the original problem. The Configure Primitives LOP works fine for me in a similar hierarchy. Can you attach a hip file that doesn't rely on your source alembic data?
“s@visibility = ‘visible’;” doesn't work because “visible” isn't a valid token for the visibility attribue. See https://graphics.pixar.com/usd/docs/api/class_usd_geom_imageable.html#aa0dfa061a65be443436288f7406ba3db [graphics.pixar.com] and https://graphics.pixar.com/usd/docs/api/class_usd_geom_imageable.html#af47f609f24c8023ddacc6d216eaef0f3 [graphics.pixar.com]
That second method, MakeVisible, is what the Configure Primitive LOP is doing to make the child primitive visible even if some ancestor primitives are invisible.
mtucker
Thanks for the fast reply! For the config prim LOP, can you test with the attached alembic? It´s the alembic exported from the hiplc file I´ve attached in the first post. There is a LOP net in that file too.
box.abc (2.7 KB)
That file still works fine for me.
Is the scene graph tree definitely showing the stage after applying the configure primitives LOP? And the box isn't showing up in the viewport?
What version of Houdini are you running?
mtucker
Yes, the scene graph shows that the prims are invisible (attached file).
I´m on build 456. I´ll update to see if it was the problem.
Anotação 2020-05-22 145335.png (772.1 KB)
mtucker
Just confirming that, on build 473 the configure primitive LOP is working and changing the prim visibility.
Glad to hear it! Thanks for reporting back.
