RBD Material Fracture Distorts UV's [SOLVED]
   6807   6   0
Hello guys,
I'm a bit stumped by this. Basically I have a piece of stained glass that I'm fracturing by throwing a brick through it. I'm using a UVTexture node with a Perpective from Camera to create my UV's.
Unfortunately while everything looks fine when the glass is pre-fractured, the moment I instance the RBDMaterialFracture node to create my glass fractures, my UV's (and image) become distorted.
I can't figure out how to get my projected image to look correct….any ideas?
Edited by Midphase - July 30, 2020 20:06:07
SOTS_SHOT_1_v3_3Delight1_0001 2.jpg (1007.0 KB)
RBD_UVs.hiplc (1.2 MB)
>>Kays
Hey,
Just out of curiosity why not to project UVs after the pieces are fractured?
Because then this happens:
>>Kays
The UVs are fine. Just unpack the high-res geo, and you can see they are present and correct.
It could be an issue of packed geo not being unpacked during render correctly maybe.
I just tested in Mantra and I get the same distorted results. I don't think this is a 3Delight bug.
>>Kays
what's wrong with it?
seems okay for me, accounting for the fact that perspective projections will be distorted due to their non-linearity.
fracturedproject.hip (290.9 KB)
Ok, thanks to TinyHawkus' help I think the issue is solved.
Basically the two things that made a difference were to use a PolygonMesh for my stained glass geometry as opposed to a simply Polygon, and then place the UVTexture node immediately after the RBDMaterialFracture.
This yields an 100% match to the footage plate.
Thanks everyone!!!
For those curious, here's what my final node tree looks like:
Screen Shot 2020-07-30 at 4.40.55 PM.png (104.8 KB)
>>Kays
