Polygon vs Mesh
   4606   1   0
I wonder what is the difference between these two?
If I create a group range node, set grouptype to primitive, set filter select 1 of 2.
Polygon will be able to select every other primitive, but if you set the Tube's type to mesh, all primitive will be selected.
I tried to check the documentation, but don't think I am very good understanding it. So can anyone explain? Thanks!
So this is the result for mesh:
This one is for polygon:
Edited by ophie - Aug. 24, 2020 11:31:35
A mesh is more like a nurb surface with linear interpolation between points. If you look at the polygon numbers with a cylinder set to “mesh” rather than “polygon”, you will see that the sides all have the same number.
Edited by anon_user_38315714 - Aug. 24, 2020 12:53:19
