I wonder what is the difference between these two?
If I create a group range node, set grouptype to primitive, set filter select 1 of 2.
Polygon will be able to select every other primitive, but if you set the Tube's type to mesh, all primitive will be selected.
I tried to check the documentation, but don't think I am very good understanding it. So can anyone explain? Thanks!
So this is the result for mesh:
This one is for polygon:
