Art Direction velocity fields on interior of object
2828 5 0-
- yaniboy
- 4 posts
This is my first post to this forum so please let me know if I can do anything to provide more information to assist anyone in answering my questions.
I am looking to create a custom velocity field limited to the interior of an object. I have a couple questions.
I am using a vdb to create my velocity field. Is there a way to limit that velocity field to the interior of my object opposed to the limits of the bounding box?
What would be a good method to procedurally create fields that turn away from the interior surface of my object to create the look of flow inside of the object. I have tried using collision which could work but is very expensive and not very art directable.
Thanks in advance,
Yani
Thanks in advance,
Yani
- Enivob
- 2658 posts
- yaniboy
- 4 posts
Thank you very much Enivob for your response. This is helpful. I am now curious if there is a way to merge this velocity with the one I had previously. The effect I am after is an hourglass with sand flowing from the bottom to the top section and I would like the top section to appear turbulent. I have tried various maths in vops to combine the tangential velocity field and a curly cross product velocity field. Actually the initial field I uploaded is a combination of a cross product and the tangential field I generated using an add node in vops but did not yield the result I wanted. I have also tried volume merge in sops but it doesn't appear to work. I feel like I am missing something very obvious.
Edited by yaniboy - March 13, 2021 12:24:45
- mestela
- 1854 posts
This might give you some ideas.
The curlnoise vop has options to steer noise away from a surface, some more notes here:
https://www.tokeru.com/cgwiki/index.php?title=HoudiniVolumes#Swirly_lines.2C_or_worms_with_volumes_and_curl_noise [www.tokeru.com]
- yaniboy
- 4 posts
This is awesome! Thank you Matt! I hadn't thought to use the curl noise in this fashion and I think this will get me on the right path. Also I never realized I could use the alpha attribute like that. I will definitely use that again. Thank you for all the work you have put into the cgwiki.
Edited by yaniboy - March 14, 2021 00:51:40
- snailsnell
- 5 posts
