Hello guys,
How can I control the Color and the Alpha of a pyro sim, using some attributes like Cd and Alpha?
I mean I would like to use those attributes to change some parts of the pyro sim look.
I will render this in Redshift...
Thanks for helping.
How can I control the Color and Alpha in a Pyro sim?
3427 3 0-
- Masoud
- 426 posts
- Masoud
- 426 posts
Here is my test scene and so far, I tried this:
1) I created a (vector point) attribute called "absorption".
2) I added this attribute's name to the "Volume Rasterize Attribute", attributes list, to create a volume called "absorption"
3) In the "volume source" node of my pyro DOP, I added "absorption" as the source and target field (as vector type).
4) I add a "VDB vector merge" node before my pyro material node.
5) In the RS Volume material, I add "absorption name into the color channel.
But it doesn't work..! How can I fix it?
Masoud Saadatmand (MSDVFX)
- Masoud
- 426 posts
- cncverkstad
- 173 posts
@Masoud
if you make min and max values ..try to play with this and change(tweak) some Fields in vex ..just play with setup and read
HELP
When this option is enabled, Cd and Alpha fields will be added to the smoke object, containing the smoke color and color amount, respectively. If the Pyro Solver detects the presence of these fields, it will ensure to evolve them as the simulation advances.
Note
Use Cd as the Diffuse Field in Multi Field visualization to display the smoke with its colors.
_______________________________
Controls the initial (and minimum) value of the Alpha field. Intuitively, the fluid will contain Default Alpha amount of dye of Default Color at the beginning of the simulation.
HELP
Note
Conservation of Momentum
