Vellum external hair collisions
   1693   2   1
I working on some Vellum hair sims, and I noticed that when "External Collisions" are activated in the "Vellum Collisions" tab, the input field for the collision objects seems to only allow a single object input.
Is there a way to add multiple objects ? Or should one really first merge all the collision objects into a new SOP and add that object ?
Thanks.
As a rule of thumb, a single input accepts a single connection. Is there a reason why you don't want to merge the collision objects?
I don't want to merge the collision object. But it seems it's the only way to add multiple objects.
I have several external collision objects, I suspect it's something that happens a lot. So I expected to be able to simply add all the collision objects, just as I can add multiple groups into a single input.
