Material LPE
3378 6 4-
- lloydwood
- 107 posts
I'm am trying to get an LPE for a material in my scene. Is this possible in Karma? I basically want to be able to tag a material and then use that tag in an LPE to get just that material's contribution to the beauty. I've tried all sorts of stuff but I can't get it working. Has anybody managed to do this?
- Damian Fulmer
- 4 posts
- 8192 posts
- j00ey
- 102 posts
I'm trying to figure out the best way to do this too -
I managed to make a new AOV with the Additional Render Vars LOP, just by copying settings from another AOV and inserting my object LPE tag. For some reason though if I put that downstream of my Karma Render Settings LOP it doesn't render, whereas if it's upstream it does. I can see the Render Var in the Scene Graph in both cases and I can't see any difference between the 2...
Can anyone advise?
Can anyone advise?
- 9454 posts
- Damian Fulmer
- 4 posts
I understand that I can use a Cryptomatte setup as by material. This is really great for getting arbitrary mattes for things. From my workflow it's also good to have a predefined set of mattes that compositors can rely on. I've found something similar in Renderman and in Arnold:
https://rmanwiki.pixar.com/display/REN23/PxrMatteID [rmanwiki.pixar.com]
https://docs.arnoldrenderer.com/display/A5AFHUG/Passthrough [docs.arnoldrenderer.com]
I hope karma can support something like this in the future.
- npetit
- 451 posts
j00ey
In order for a render var to be "acknowledged" it needs to be added to a render product which needs to be added to the render settings.
While in both cases the render vars will be created, when creating them upstream of a Karma Render Settings LOP, the Karma Render Settings LOP will automatically add them to the default render product (/Render/Products/renderproduct) which is added to the render settings (/Render/rendersettings). Creating them downstream will only create the render vars.
Check the /Render/Products/renderproduct's "orderedVars" relationship to see which render vars are associated to it.
Check the /Render/rendersettings' "products" relationship to see which render products are associated to it.
