chopnet export randomize for multiple object
   3354   8   0
A greeting!
I would like to find a solution to this problem, I hope hodini does not disappoint me!
I have a chopnet from which I export a channel, I would like to export this channel to different objects and for each one to create a random version of my wave, is it possible?
English is not my native language, sorry in advance for any misunderstanding!
Could you share a file? just a simplified concept would work. Guessing is not very effective.
Edited by SWest - Nov. 3, 2022 15:35:37
SWest
There he is! I would like to have more variations of the same animation with a single export from the chopnet. So that each cube had different times. it's possible?
chopnetvar.hiplc (77.3 KB)
Like this?
Edit: The code (in this version) was done close to midnight, so it is not cleaned up. It just barely works.
Quick version:
If you want the quick version try using this in the target geo inputs. However, you will need to add it manually to each geo and change the offset number (3 in this example).
Also "../button/input" must go to the source parm that is supposed to get a time offset.
hou.parm("../button/input").evalAsFloatAtFrame(hou.frame()+3)
Edited by SWest - Nov. 6, 2022 02:06:42
swest_screen_capture_20221105_0012.mp4 (6.3 MB)
Here's an updated version. If the video is too slow for you just jump ahead (probably with arrow keys).
swest_screen_capture_20221106_0748.mp4 (14.1 MB)
SWest
Thanks does what I ask, now I try to understand the code you wrote!
Davide Ruzzenenti
SWest
The last video got cut, but you can ask your questions here.
Edit: the last part of the updated code is missing from the video (max filesize of video). Tell me if you need it. The first code also works.
import random
# data input parm
input_parm_path = '../button/input'
# data output parm
sibling_nodes_prefix = 'box'
out_parm = '/ry'
# settings for randomization
# random frame offset (how much to depart from original frame)
rand_offset_from = hou.parm('../button/a_int').eval()
rand_offset_to = hou.parm('../button/b_int').eval()
# used to get the same results twice
seed = hou.parm('../button/c_int').eval()
random.seed(seed)
# fix for b_int
if rand_offset_to <= rand_offset_from:
    rand_offset_to = rand_offset_from+1
    hou.parm('../button/b_int').set(rand_offset_to)
# select all box* and put in list
items_list = []
parent_node_path = '/obj/geo1/' # todo: make procedural
parent_node_children = hou.node(parent_node_path).children()
for child in parent_node_children:
    if sibling_nodes_prefix in child.name():
        items_list.append(child.path())
# fix for imported py code (node, not hip)
hou.parm('/obj/geo1/chopnet1/export1/path').set('')
hou.parm('/obj/geo1/chopnet1/export1/path').set('input')
def a():
    for each in items_list:
        r = random.randrange(int(rand_offset_from),
                             int(rand_offset_to))
        child_parm_path = each+out_parm
        child_parm = hou.parm(child_parm_path)
        hou_keyframe = hou.Keyframe()
        hou_keyframe.setTime(0)
        hou_keyframe.setExpression('hou.parm(\
"'+input_parm_path+'").\
evalAsFloatAtFrame(hou.frame()+'+str(r)+')', \
        hou.exprLanguage.Python)
        child_parm.setKeyframe(hou_keyframe)
Edited by SWest - Nov. 6, 2022 10:29:46
here is a more straight forward chops way to do it.
chopnetvar.hiplc (99.5 KB)
That's some chops wizardry right there. Thanks for sharing!
