How can I snap the Draw Curve node to draw straight lines on
   2476   2   1
I guess this is a noob one. But can´t find any explanation or shortcut to snap it and my lines get too curved.
Thanks.
You could use the line sop and then project it using a ray node if that is what you want.
I could not find a force straight line option on the draw curve. If there isn`t one it might be a good idea to add it. at the very least to the documentation.
Edited by NicTanghe - Nov. 4, 2022 11:25:55
If you need straight hand-drawn curves, you can later resample them down to 1 segment.
If you require your curves to remain slightly, well, curvy, you can use more segments in the Resample SOP and then convert the curves to NURBS.
Edited by ajz3d - Nov. 4, 2022 13:21:15
