How do I know what frame to start and end of alembic?
3628 4 0-
- Duan
- manja
- 21 posts
- sanostol
- 611 posts
You can middele click on the node in the networkview
or if You need it automated:
the values are the actual samples, so if You have motion samples they have a additional step
import _alembic_hom_extensions as abc time_range = abc.alembicTimeRange(archive_path) start_frame = timerange[0]*hou.fps() end_frame = timerange[1]*hou.fps()
Edited by sanostol - Nov. 30, 2022 05:12:10
- Duan
sanostol
or if You need it automated:the values are the actual samples, so if You have motion samples they have a additional stepimport _alembic_hom_extensions as abc time_range = abc.alembicTimeRange(archive_path) start_frame = timerange[0]*hou.fps() end_frame = timerange[1]*hou.fps()
sanostol
or if You need it automated:the values are the actual samples, so if You have motion samples they have a additional stepThanks import _alembic_hom_extensions as abc time_range = abc.alembicTimeRange(archive_path) start_frame = timerange[0]*hou.fps() end_frame = timerange[1]*hou.fps()
- 9416 posts
One inconvenientce may be that those functions return timesample at 0 for static meshes
Therefore if the real animation range (in frames) is 1001-1100
And if you also have some static meshes, it will return something like 0-1100, simply not the actual animation range
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
