Hi All,
Have encountered a problem when trying to boolean two surfaces (overlapping grids).
Ideally I'd like to have a clean surface which I can further model downstream, but it's unusable after the Boolean SOP.
Take a look at the attached HIP and screenshot.
Any help would be much appreciated.
Boolean SOP Problem
2429 6 1-
- netlander
- 32 posts
- CYTE
- 803 posts
- netlander
- 32 posts
- 9406 posts
- netlander
- 32 posts
- Mike_A
- 392 posts
Having had the same question myself some time ago, I do wonder why this 'flat edge' removal isn't done automatically as part of the Boolean SOP. I can't think of a situation in which I'd want the sort of geometry shown in the OPs post.
Would anyone else miss it?
Edited by Mike_A - Jan. 8, 2023 16:20:17
- 9406 posts
Mike_Ayes, it's useful as that's the true union of 2 polygonal shape topologies
boolean is not merely for 2D shapes, those shapes can be anything, it would be a mess if all the flat edges were automatically removed all the time you use boolean
also Houdini doesn't have intuitive boolean for curves, the closest to it is Curve Intersect SOP, but that has it's own issues
However if there was a 2D Boolean SOP that is meant to work with (all types of) curves then yes, the assumption would be that union would keep just outlines
Edited by tamte - Jan. 8, 2023 16:58:51
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
