Adding noise to a mask?
6578 14 1-
- proceduralist
- 208 posts
- 8184 posts
- proceduralist
- 208 posts
I am still not able to get the desired result even after choosing 'primitive' in the visualize node. The noise gets applied to the entire geometry. The class was set to 'auto' in the visualized attribute node arlier. Why didn't it pickup attributes from the primitive?
Sharing a screen recording of what I experience.
- vikus
- 247 posts
You can multiply the @mask attribute by the Noise to achieve the required effect.
Just use a Point Wraggler with the following code:
Input 0 contains the mask attribute and Input 1 contains the noise attribute, like in the figure below.
// multiply the mask value by the noise from 1 input and add the result to the color attribute. v@Cd = point(1, "Cd", @ptnum) * @mask;
Edited by vikus - March 29, 2023 15:38:57
- Tanto
- 545 posts
- 8184 posts
proceduralist
leave the visualize node on auto. The noise is being generated on primitive which isn't what you want. Change the noise to generate on points.
- proceduralist
- 208 posts
jsmackproceduralist
That's what I did. Still not working. I think it's because the tutorial I'm following was made on Houdini 18.
Here's a snippet of what exactly he's doing.
I tried again. Still failing.
I have switched on all the legacy nodes in Houdini 19 using opunhide command and ensure that they load everytime Houdini starts up. Unfortunately the old attribnoise node is gone forever.
Edited by proceduralist - March 30, 2023 02:28:56
- proceduralist
- 208 posts
vik_lc
Just use a Point Wraggler with the following code:// multiply the mask value by the noise from 1 input and add the result to the color attribute. v@Cd = point(1, "Cd", @ptnum) * @mask;
Input 0 contains the mask attribute and Input 1 contains the noise attribute, like in the figure below.Image Not Found
Good old VEX code to troubleshoot everything in Houdini life. I'll try your method and get back. I try to minimize VEX in my workflow unless really necessary.
- 9417 posts
proceduralistit's not gone, it's just the same name, older version
so enable Assets/Asset Definition Toolbar/Show Always
and then switch the version of your node from the top dropdown menu in Parameter Pane
here is the file with both versions of the Attribute Noise working
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- 8184 posts
proceduralist
It is working in your video until the type was changed away from points. The original hip file is also working after changing primitive to point. The amplitude of the noise is such that the original mask contributes much less than the noise value to the addition. The visualizer has 'treat as scalar' with length enabled, which probably not desired as this causes the values be be visualized as absolute values obscuring the actual behavior.
- proceduralist
- 208 posts
tamteproceduralistit's not gone, it's just the same name, older version
jsmack
Thanks a lot @tamte and @jsmack. I compared the newer version of attribute noise with my own file with tamte's file considering the points mentioned by jsmack.
I am able to achieve the noisy mask but the whole sphere gets a shade of red in non masked areas as well. I can't figure out why is that happening.
I feel I should learn the newer node as the older one will get removed forever.
- 9417 posts
- proceduralist
- 208 posts
- 9417 posts
proceduralistah ok, sorry, didn't check your whole video
The first attribute noise is set to add, the second one has multiply.
it seems like your mask visualization range is set to Auto
and you are not clamping negative values in attribnoise postprocess, so it may be simply visualizing 0 as not black and overall may be difficult to make sense of mask values if the range is Auto
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- proceduralist
- 208 posts
tamteproceduralistah ok, sorry, didn't check your whole video
Okay. I'll check once again and get back to you. This is getting really difficult to understand. Man, thanks a lot for helping me out here. At the risk of sounding cheesy, if I ever win an award for a project that involves Houdini, in my award speech, I'm gonna thank you and jsmack besides Rohan Dalvi and Mark Fancher. You guys are so helpful. Seriously.
Edit.
Alrighty! Finally! I just checked Rohan Dalvi's video that I shared here earlier. He doesn't do any settings in his visualize node and everything comes out well for him.
Were there any changes made in Houdini 19?
Edited by proceduralist - April 3, 2023 11:07:51
