Changing the length of multiple lines while keeping points
   1951   4   1
Hi all, I'm looking to randomly changing the length of multiple lines whilst keeping the number of points across the whole system the same.
For example, I have 4 lines with 11 points each, I want to randomly change the length of these lines, but keep the overall number of points to 44.
Maintain_points.hiplc (100.7 KB)
Try dropping down a GuideProcess (Set Length) node and activate Randomize. Adjust the min/max values to chose an average height.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thank you, that did exactly what I asked! However, I've realised I actually asked the wrong question. How can Randomly change the lengths while keeping the overall length of the sum of the lines the same?
bashorton
I supplied a hip that does this similarly for you in your other post. You just have to make a bit of modification for your current query; It's the same logic.
mass_system_v0.hiplc (154.9 KB)
BabaJ
bashorton
Thanks so much! That works really well, I'm going to go through the vex to try and work out how you achieved it.
