How to create spline from points
   3129   9   2
Hi, I want to crate spline which follows the point direction. it's hard to connect this way, if I just try to connect the closest that won't be right in some cases, specifically in the corner. Anyone has a idea how to do that?
Edited by Beka - Aug. 31, 2023 12:20:15
Screenshot 2023-08-31 173536.png (581.8 KB)
if they happen to be in right point order just use "add" sop enabling by group under polygons tab. Or otherwise if they somehow have fitting attributes you can also use 'add' to connect them via the attribute
Lucca
Thanks Lucca!
Problem is that I don't know the right point order. I have not any information, only this.
You can look up points in the direction of the previously found point by making an exception in the first point and limit your search to a cone angle using pcopen:
https://www.sidefx.com/docs/houdini/vex/functions/pcopen.html [www.sidefx.com]
Alternatively you can implement the same cone angle yourself and use the newer pcfind VEX functions.
animatrix_
Thank you!
I thought something similar and probably it is the only way. I can not see how can I transfer cone information into pcopen(), but now I've found function of pccone() which can get direction and cone angle, (Wow I don't know that function). I think it will be difficult in the corner area, but yeah it will be good starting point
float pos_arr[] = {};
for(int i=0;i<@numpt;i++) {
    vector p = point(0, "P", i);
    push(pos_arr, p.z);
int ordering[] = argsort(pos_arr);
ordering = reverse(ordering);
    setpointattrib(0, "sort_index", ordering[i], i);
sort by index and Add.
Conservation of Momentum
cncverkstad
    push(pos_arr, p.z);
Thank you so much!
It has problem when curve turns around
Screenshot 2023-09-05 173540.png (890.8 KB)
For that you can use
Euclidean Minimum Spanning Tree by Satoru Yonekura that I got those codes from.
foreach(int pt; nearpoints(0, @P, 1.0, 10))
    if(pt == @ptnum) continue;
    vector p = point(0, 'P', pt);
    float dist = distance(p, @P);
    int ptsA[] = nearpoints(0, @P, dist);
    int ptsB[] = nearpoints(0, p, dist);
    int chk = 0;
    foreach(int cpt; ptsB)
        if(cpt == @ptnum || cpt == pt) continue;
        chk = removevalue(ptsA, cpt);
        if(chk) break;
    if(!chk)
        int pr = addprim(0, 'polyline');
        addvertex(0, pr, @ptnum);
        addvertex(0, pr, pt);
Clean
Convertline
detail wrangle
int ptlist[];
for(int pt=0; pt<@numpt; pt++)
    push(ptlist, pt);
int newlist[];
push(newlist, 0);
removevalue(ptlist, 0);
while(len(ptlist) > 0)
    float mindist = 10000;
    int newpt = -1;
    int newedge = -1;
    foreach(int pt; newlist)
        foreach(int prim; pointprims(0, pt))
            int targetpt = primpoint(0, prim, 0);
            if(targetpt == pt) targetpt = primpoint(0, prim, 1);
            if(find(newlist, targetpt) > -1) continue;
            float dist = prim(0, 'restlength', prim);
            if(dist <= mindist)
                mindist = dist;
                newpt = targetpt;
                newedge = prim;
    if(newpt == -1) break;
    push(newlist, newpt);
    removevalue(ptlist, newpt);
    setprimgroup(0, 'newedge', newedge, 1);
blast not newedge
Have Fun
Edited by cncverkstad - Sept. 5, 2023 12:09:31
cncverkstad
    int chk = 0;
        if(chk) break;
    if(!chk)
Clean
Convertline
detail wrangle
int ptlist[];
    push(ptlist, pt);
int newlist[];
push(newlist, 0);
    int newpt = -1;
    int newedge = -1;
            if(dist <= mindist)
                mindist = dist;
                newpt = targetpt;
                newedge = prim;
blast not newedge
Have Fun
Wow it works! amazing!
Only the areas where I have harsh edges have a problem, but the rest is great!
Thank you!
change some values of code to made exact matching .it should work .Have Fun .
