I'm using a filecache to save a popnet simulation, how can I read it inverted to obtain like "a backward effect" of my sim?? Of course I already tried with a negative increment, but it didn't work...
Is it possible directly into the filecache or not? Maybe with a Timeshift after the Filecache?
OK it works if I just reverse the Output Frame Range, Houdini understand itself the negative step! Cool!
But... When I play backward the sim, I lose the orient of the point for the last frame, and for an appearance effect it's a mess into the pieces of my object... :/
ShkYo30 OK it works if I just reverse the Output Frame Range, Houdini understand itself the negative step! Cool!
I'm not sure where you're seeing an output frame range, is that with the retime node? With the timeshift node there is only a frame or time parameter, so to reverse the playback, remap the frame value to the reversed range. For example, put $FEND-$F+$FSTART for the frame expression, or link to the file caches start and end parameters instead of using the global variables.
jsmack ... I'm not sure where you're seeing an output frame range, is that with the retime node? With the timeshift node there is only a frame or time parameter, so to reverse the playback, remap the frame value to the reversed range. For example, put $FEND-$F+$FSTART for the frame expression, or link to the file caches start and end parameters instead of using the global variables.
Ok I understand well your tip, and it's noted! Thanks for the idea!
In my case, I just inverted the "Output frame range" in "Fit range" mode and Houdini understood to use a negative step (look the screenshot just below), cool!
