How to delete primitive based on distance from one another?
   3313   6   1
Is there a way delete primitives based on a distance threshold from other primitives. I have a DNA sphere and it's almost working except there are some single letters primitives (ex like the ones highlighted) still floating around that I'd like to remove with an attribute wrangle. Thanks.
Edited by cpinto - Dec. 17, 2023 02:38:10
Screenshot 2023-12-17 022831.jpg (206.8 KB)
If you don't need to use connectivity, you can create a point per primitive and then perform a point cloud look up like this:
create_pts_per_prim (Primitive Wrangle):
addpoint ( 0, @P );
removeprim ( 0, @primnum, 1 );
id (Point Wrangle):
@id = @ptnum;
pcfind (Point Wrangle):
int pts [ ] = pcfind ( 0, "P", @P, ch("radius"), chi("maxpts") );
if ( len ( pts ) > 1 )
    removepoint ( 0, @ptnum );
delete_prims (Primitive Wrangle):
int index = findattribval ( 1, "point", "id", @primnum );
if ( index == -1 )
animatrix_
addpoint ( 0, @P );
id (Point Wrangle):
@id = @ptnum;
if ( index == -1 )
Heya Animatrix_,
Thanks for that, I tried it and it looks like it does the inverse? So it removed everything but the floating circle letter primitives. Is there a way in vex to say do the opposite. Thanks again.
Screenshot 2023-12-17 022832.jpg (102.3 KB)
Oh wait, sorry I found it.
I just change the delete_prims wrangle from
"int index = findattribval ( 1, "point", "id", @primnum );
if ( index == -1 )
removeprim ( 0, @primnum, 1 );"
to
if ( index > -1 )
either that or also
to
if ( len ( pts ) == 1 )
this would delete only points that find only themselves within the radius and therefore are isolated
which may be easier for visualization as it would delete points whose corresponding primitives you want to delete rather than deleting all other points and then delete prims for remaining points
CG Supervisor
Framestore, NY
cpinto
if ( index == -1 )
to
if ( index > -1 )
Oh yes sorry I didn't realize you wanted the inverse. So you could just do it like you did or tamte but in your example, the proper inversion is:
if ( index != -1 )
Ah ok, thanks for the help folks and explanations.
