So I was in a situation where I had the verify the data type of some values using a printf statement. So, for the first time, I come across the typeid() function. Which returns integer numbers instead of words like float, integer, vector 2, etc. So I searched google to find out if there is correspondence list somewhere which can tell me what number corresponds to what datatype. Scarcely do I find anything. I was almost troubled, like: no one is ever checking the return type of vex values; Is there another way"
Sidefx help docs also seldom mention it. So question is: am I missing something?
Anyway I went on to create my little vex snippet to tell what what IDs are what. Basically
vector myvar;
printf(%s,typeid(myvar)); which returns 3
vector myvar;
printf(%s,typeid(myvar)); which returns 13
Or
int myvar;
printf(%s,typeid(myvar)); which returns 0
int myvar;
printf(%s,typeid(myvar)); which returns 10
or
float myvar;
int myvar;
printf(%s,typeid(myvar)); which returns 11
and so on...
As you can see, there is a pattern where if the Id of a type is n, the array of that that same type will be 1n
Vex typeid seems to be a mystery
1727 4 2-
- Leozard
- 18 posts
- vikus
- 247 posts
Oh glad to see this post, recently struggling with attritype [www.sidefx.com] to get a diffirence between a vector4 and a matrix2. But finally there is a solution H20
Here is a kind of wrapper function to get the name of the data type instead of the id:
Here's a generic [www.sidefx.com] attempt, works only with none array types. Can't figure out how to impliment them?
Here is a list of the type names mapped to the id:
string gettype(int id) { string type[] = {"int", "float", "vector2", "vector3", "vector4", "matrix2", "matrix3", "matrix4", "string", "dict", "int_array", "float_array", "vector2_array", "vector3_array", "vector4_array", "matrix2_array", "matrix3_array", "matrix4_array", "string_array", "dict_array"}; return type[id]; } printf("%s \n", gettype(typeid(d@test)));
#define GENERIC_MACRO(TYPE) \ string gettype(TYPE data) { \ string type[] = {"int", "float", "vector2", "vector3", "vector4", "matrix2", "matrix3", "matrix4", "string", "dict"}; \ return type[typeid(data)]; \ } \ GENERIC_MACRO(int) GENERIC_MACRO(float) GENERIC_MACRO(vector2) GENERIC_MACRO(vector) GENERIC_MACRO(vector4) GENERIC_MACRO(matrix2) GENERIC_MACRO(matrix3) GENERIC_MACRO(matrix) GENERIC_MACRO(string) GENERIC_MACRO(dict) #undef GENERIC_MACR printf("%s \n", gettype(d@test));
0 - int 1 - float 2 - vector2 3 - vector 4 - vector4 5 - matrix2 6 - matrix3 7 - matrix 8 - string 9 - dict 10 - int array 11 - float array 12 - vector2 array 13 - vector array 14 - vector4 array 15 - matrix2 array 16 - matrix3 array 17 - matrix array 18 - string array 19 - dict array
Edited by vikus - March 12, 2024 16:45:13
- Leozard
- 18 posts
- vikus
- 247 posts
You can use external vex libraries similar to python modules.
Under $HOUDINI_PATH (Win: C:\Users\*user\Documents\houdini20.0\) you can add a "vex" folder if it is not already there. Within the vex folder, create another folder with the name "include". Here you can save your external vex files with the "vfl" suffix.
For example:
$HOUDINI_PATH\vex\include\my_vexlib.vfl
Now this function can be called within a wrangle by importing the file with the "#include" preprocessor:
Your can even define structs [www.sidefx.com] this way, which allows a kind of semi-object-oriented programming.
It is also possible to embed vfl files in others, which leads to more complex library structures.
For example:
int foobar(int a, b) { return a + b; }
#include "my_vexlib.vfl" int n = foobar(5, 10); printf("%d \n", n);
Edited by vikus - March 15, 2024 18:03:32
- Leozard
- 18 posts
Thanks Viklc. Trying that now.
