Bounding box size of a group
   1668   3   0
Is there a way to reference the bounding box size of a group within a primitive without blasting that primitive group ?
In my specific case I would like to Xform just the group on Y according to it's Y size
"bbox(0,D_YSIZE)" considers the entire primitive Ysize and not the group entered above in teh group field. Is there a dedicated expression or a workaround to do so ?
Thank you
Edited by Chawki - May 19, 2024 14:52:05
you can use Match Size SOP [www.sidefx.com] for this, check on "Use Groups to Determine Justification Bounds" parm and choose primitive group in "Source Group".
Or use Attribute Wrangle SOP and vex functions getbbox_size() [www.sidefx.com], getbbox_center() [www.sidefx.com]
Chawki
Thank you
For max performance I would recommend using the Bound SOP and then referencing this node in your bbox expression.
animatrix_
Chawki
Thank you
WOnderful !
