Different shader in GL/Vulkan than with Karma (XPU)
1375 3 0-
- ronald_a
- 202 posts
I would like to have different shaders showing when working in the realtime viewport (GL/Vulkan) and with Karma. I tried using a collect node and connecting a usd preview surface and mtlx standard surface to it. but because the mtlx shader can be displayed with GL as well it would pick that instead of the usd preview surface. I also tried to use a configure primitives LOP to set the two shader's purposes, but that didn't work either. Is there a way to tell solaris exactly which shader to use (in the end I would even like to have two mtlx shaders).
- Ben Toogood Aardman
- 75 posts
- Heileif
- 290 posts
Could try this.
"HOUDINI_GL_USE_MATERIALX
Enable support for MaterialX and Karma materials in the Houdini GL render delegate in the LOP context. The default value is 1.
0
MaterialX and Karma materials are not supported.
1
Both MaterialX and Karma materials are supported.
2
Only MaterialX is supported."
https://www.sidefx.com/docs/houdini/ref/env.html [www.sidefx.com]
0
1
2
- ronald_a
- 202 posts
