Getting the blocky SDF look as polygons
   1299   3   1
While setting up a scene, I ended up rendering a SDF vdb as is in Karma, and I love the blocky look I get. I could really use this as a basis going forward, but I'm having trouble converting it to polygons without getting a smooth result. My impression is that I would need to convert it to a mesh that surrounds all activated voxels without any smoothing. Any idea how I could get that?
Maybe you could use points from volume, copy cubes onto the points, and put them in a boolean afterward to delete all inner faces.
CYTE
Edited by CYTE - Feb. 22, 2025 10:21:13
Thank you CYTE, I'll try that.
The VDB visualize tree node creates boxes on 'active voxels':
https://www.sidefx.com/docs/houdini/nodes/sop/vdbvisualizetree.html [www.sidefx.com]
